The waste gases from the furnaces are run through a condenser to reduce the amount of water that enters the NOx abatement stage. The incondensibles and a small amount of water that remains in the vapour are then passed on to NOx abatement. The water that is condensed can simply be discharged, as it will contain minimal contaminants.
Guest_kayrichardson_*
Posted 05 March 2012 - 10:07 PM
Posted 05 March 2012 - 10:23 PM
Posted 05 March 2012 - 10:47 PM
All our senior / professional members want to help you - that I can assure you. But your first post was extremely long!!! I took about 15 minutes to copy it into Word for Windows and it is contained in 54 pages!! That is absurd. We can't possibly handle that much verbiage. We want (and need) specific and detailed basic data and scope of work in order to help you and guide you as much as possible - but 54 pages is ridiculous. (look at the attached copy of your initial post)
Now I see that as I was copying your first post, you returned and submitted an attachment with a reduced post. Thank you! However, I don't see how we can much use all the stuff you crammed into 54 pages. What I've gleaned through reveals that most - if not all - of the data does not apply to what you refer to: a shell and tube condenser.
Please be concise and relevent in giving us the detailed data we require:
- a sketch of the the process;
- description of the type of TEMA condenser you are proposing to use;
- a heat and mass balance showing the total heat transferred - broken down into sensible and latent heat loads;
- a full description of the pressures, temperatures, compositons, and phase of each stream in your process (the condenser); this includes the utility fluid you intend to use as the coolant.
- use an Excel Workbook to submit all your information.
As you can see by what I have described as the essential information, we don't need 54 pages of writeup. Our responses will probably be done right on your Excel workbook - in the form of remarks, sample calculations, and comments on your work.
If you are in a hurry because you have waited a long time before asking for help and guidance, then please tell us your timetable and schedule for finishing this assignment. In order to help you, we need to know ALL the facts.
Posted 07 March 2012 - 07:03 AM
Thanks for your reply. I had a meeting with my supervisor yesterday and he said i cannot use shell and tube condenser and he has asked me to design a another type of condenser. This is because my head load is small and also my heat transfer coefficient is also small. The whole idea of my design is to reduce water in the waste gases coming from 2 furnaces (actinides and americium furnaces). I am dealing with a radioactive materials as this also needs to be put into consideration. My supervisor was saying that because my head load, heat transfer coefficient and flow rates are small, then i should be thinking of a jacketed pipes which till now i really don't understand what he meant, although he was saying that a single pipe in the condenser design should be enough to carry out this work for the condenser. He also mentioned about shed 40 pipping to be used as its a nuclear/radioactive plant.
I also need to let you know that the only component am designing is a condenser and all other component are to be ignored. On the process flow diagram (PFD) generated from HYSYS ASPEN, component 21 and 22 represent the americium and actinides furnaces going into the furnace condenser which is the component am designing, 24 is the condensed water with little contaminant from the condenser am designing and 23 is the non-condensable gases and maybe little water vapour going into the Nox abatement. The waste gasses from both furnaces are assumed to be going into the condenser at 500 C and cooled to 20 C. we need to guess or assume the working pressure of the condenser. i would imagine that the pressure drop must not exceed 1 bar, maybe illterations might be applicable in this case. The coolant can either be water or air but my supervisor was mentioning water.
With regards to reference (perrys and richard and coulson vol 6)
This project is about separating 99.5% americium from a stored plutonium stockpile.
I have attached the PFD of my design
I have attached he instructions for my design project
I have attached the physical property document given to me by my supervisor
I have included the mass balance for this design both on pdf and excel file
I have attached the energy balance as well.
I really hope i have given you enough information. I really don't know how to thank you. This is a big work andy am really trying on my own end to do this. Looking forward to your reply. Thanks
Posted 07 March 2012 - 09:36 AM
Thank you for the detailed explanation. Now we are getting down to the "meat" of the assignment. I haven't had the time to go through all your submitted documents, but after reading your post, I believe I can “translate” what your supervisor is stating.
I think he (or she) is trying to give you a “heads up” (a hint) on what is expected. I think he/she already knows that the heat load to be calculated is going to be rather small. This is a nice gift (the hint), and the advice should be followed – if it has been given in good faith. The advice alludes to the use of what is called an old-fashioned, “double-pipe” heat exchanger. Mr. Donald Q. Kern, in his great book – “Process Heat Transfer” – describes this type of simple, small exchanger and gives examples of how to design it. I highly recommend you obtain a copy of this book either through your tech library or a used source – like the Internet.
This should be a “fun” project because it is rather direct and simple to apply. The basics in heat transfer should be known and applied as well as a design of a vapor-liquid separator after the latent heat exchange in order to effect a phase separation between the resulting cooled gases and the condensate.
I (and probably other Forum members) will work on your submitted documents and keep you informed on our comments, guidance, and recommendations.
Posted 07 March 2012 - 10:05 AM
I will go to the library now to look for the book. I just hope all copies are not gone. I will be working on it from my own side and would also be looking forward to your brilliant expert feedback towards this project. At least if you can help me with design concept, then i can have a grasp for future approaches. Thanks
Kay
Posted 10 March 2012 - 10:54 PM
I've been on a 3 day trip and see that you are lagging on this subject.
I've tried to accelerate your action(s) on this topic by working on your submitted spread sheet. The simple (and downloaded simulator - Hysis?) and not-applicable Process Flow Diagram does not explain what you write. Note that my PFD is SPECIFIC to the topic at hand. This is the kind of data you should be generating in order to communicate clearly and specifically. Downloading a Hysis simulator diagram (that is NOT A PFD) is just a student's lazy way of avoiding the necessary work involved in communicating your problem. All too many engineering students are refusing to invest time and effort in resolving their own problems. They always look for the "easy" way out of doing work. In this case see how simple the answer is depicted and illustrated.
Also note the comments I've added to your submitted data sheet.
I hope these comments and PFD clearly tell you how to resolve this problem - together with the Don Kern instructions in his book.
Edited by Art Montemayor, 17 March 2012 - 02:29 PM.
Revision to PFD
Posted 12 March 2012 - 07:08 AM
Thanks for your reply. You have been very helpful but to be honest i am very confused on what to do next. I am thinking if you have a Skype account and you are free, we could run the design together while on Skype. If you let me know the time and day you will be free that could help. My Skype name is steve Oladimeji. I am based in the United Kingdom. I don't know the time difference of your location and mine. If you let me know, then we could resolve this as soon as possible. If you can add me please. Look forward to your reply. Thanks
Dear Art Montemayor,
I have attached a more coincise mass balance for this condenser design. The unit for every data in the excel is kg/week. Look forward to your reply. Thanks
Kay
Edited by fessy, 12 March 2012 - 08:57 AM.
Posted 12 March 2012 - 01:18 PM
I am also very confused. This thread was started by Kay Richard (male) and now I’m getting a post from “fessy” (female). I don’t know who to address and, to make it even more confusing I’m told a Skype name of “Steve Oladimeji”. How many people are involved here?
I am sorry that “fessy” is also very confused, but I thought my recommended calculation procedure was very direct and simple to follow. I would – as always – be glad to help out any student that needs it, but at present I just returned from a long engineering trip that I took last Wednesday and find myself immersed in a lot of deep problems at work (Yes, I still hold down an engineering position as technical advisor, 10 hours per day at the age of 75). The project that I am advising on has a lot of problems that must be resolved as soon as possible and the only free time I can spare is during my lunch breaks and when I get home for supper – which is monopolized by my wife. Additionally, l do not help other engineers on our Forums on a one-on-one basis. I help a lot of young engineers – especially students – but only on the Forums because that way, the information can be shared with others in a quick and efficient manner. One-on-one help is very efficient; but it only helps out ONE student. The Forum can help a much greater amount of students by being open to all members.
Additionally, you are approximately 8 hours ahead of me. That means that your nighttime is my daytime and vise-versa. Without your detailed engineering calculations, drawings, and scope of work already in place and thoroughly reviewed, a Skype session would, in my opinion, be only a social exchange and not a technical solving session.
You have submitted a couple of tables that show a balance of what is coming out of the furnaces. This is probably only a simulator output – not engineering calculations. You need to calculate the heat load on the condenser, select the cooling medium for the condenser, and calculate the flow rate of the cooling medium. With the heat load, you calculate the required heat transfer area for the condenser. All these calculations should already have been made in the submitted workbook.
I hope this helps you generate your calculations.
#10
Posted 12 March 2012 - 09:45 PM
Sorry for the confusion. Fessy is my classmate and she has access to my account and so does i have access to her account and we both study chemical engineering.
I really think the best way you can help me is if you can send me an example of an excel spreadsheet for a double pipping condenser design as you have suggested and i can follow it all through as a guideline in designing with my own specifications. I hope that make more sense to you.
Kay
#11
Posted 13 March 2012 - 01:25 PM
#12
Posted 15 March 2012 - 05:00 PM
I am almost done with the design calculation on excel. I will be sending it in two to three hrs so you can check it for me. Thanks
Kay
#13
Posted 15 March 2012 - 07:08 PM
I have finished with the design calculation for the double pipe horizontal condenser with a special E-shell (3 Nozzles). 1:1 counter-current. The shell is made up of pure copper as thats the only metal that would withstand a temperature between 500 and 600C. The waste gases includes H2O (water vapour), NO2, O2, N2, H2, N2O and Ar. The coolant use is water. There are 2 furnaces supplying the condenser with waste gases.
I have attached the excel work calculation. I had trouble with pressure drop and over all heat transfer coefficient. If you can have a look for me in all my calculation and make amendment, recommendation where necessary.
Kay
Posted 15 March 2012 - 09:36 PM
I would never rely on Copper as a material of construction for high temperatures. Have you checked the allowable stress value for Copper at your 600 oC?? I think you will find that it will be very weak.
For this type of application I would use Stainless Steel (316 ELC grade) first - if that is OK with the fluids involved.
For my comments on your "calculations" refer to my attached Rev1 of your workbook.
Where is the requested PFD?
Did you read and study the material in Chapter 12 of Kern's "Process Heat Transfer" as I recommended? Those 50 pages are full of calculations examples for your condenser.
Posted 17 March 2012 - 01:46 AM
just had a glance of your worksheet, waste gas of 600 C cooled to 20C with the help of 25C cooling water. You donot have heat sink to cool waste gas to 20C. To achieve 20C waste gas outlet, you must have cold fluid below 20C.
#16
Posted 17 March 2012 - 08:52 AM
Thanks for your reply. I have just changed it from 25C to 5C. What else in the flow sheet would you recommend for changes. Look forward to your reply.
Kay
#17
Posted 17 March 2012 - 09:03 AM
DB Shah can't address your question because you haven't followed prior requests about furnishing a detailed PFD. In fact, you haven't answered most of the questions raised.
Where is the requested PFD? There is no detailed PFD on this thread to date.
#18
Posted 17 March 2012 - 09:59 AM
I really appreciate the fact that you have put into helping me with my project. The issue is that this project is been handled by four people and i am among the 4. We are all designing 4 different component of which i have explained to you earlier what i am designing. The other 3 people are designing furnaces, SX1 and dissolution tank. The PFD i sent to you before is all we have for now. A more detailed PFD would be designed in before his project comes to an end. I cannot do this alone as its a collective work. That is why i sent you the PFD we have at the moment, including the mass and energy balances. With regards to the kerns book, i have requested it and should be collecting it on monday the 19th of march.
My project is very complicated and tough. Its a nuclear plant. I have suggested initially to send you a full copy of my part 1 report of my project but like you said before you are a very busy person and i don't want to stress you out as you have project you supervise and also there are lots of young engineers who would require your expertise just like what you are helping me with presently.
Kay
#19
Posted 17 March 2012 - 02:53 PM
I empathize with your confusion. However, it is my humble opinion that this confused situation is caused by your lack of reading and heeding prior comments and recommendations. This now makes the 19th posting on this topic and we are no closer to closure on this topic than the first post. Please read my comments on my first, initial post:
“Please be concise and relevent in giving us the detailed data we require:
Now read and heed the comments on the workbook I issued over the last weekend:
“Perceived steps to cool, condense, separate, and control the two Furnaces' flue products stream are as follows:
1) Calculate and identify the size, composition, and conditions (temperature, pressure) of the furnaces' flue exhaust gas stream;
2) Identify the conditions of the cooling fluid (cooling water?) used to cool and condense the flue gases;
3) Fix the outlet temperature of the flue products exiting the cooler condenser;
4) Calculate the cooling and condensation load of the required cooler-condenser;
5) Calculate the required size (heat transfer area) required by a cooler-condenser;
6) Calculate the amount of liquid water condensed and the amount left in the saturated vapor state with the non-condensables;
7) Design the required 2-phase separator required to separate the condensed water from the saturated non-condensable gases going to Nox abatement.”
Without your submittal of a detailed PFD and the basic data requested, it is very difficult for outstanding, professional Forum members – such as SRFISH and DBShah to help and assist you through the simple condenser design and application. SRFISH is considered an outstanding expert in heat exchanger design and his willingness to read this thread and try to help is something that would be all to your benefit if only you furnished him and other members with the information and effort requested.
You (and your colleagues) did not create a PFD. As I told you, all you sent is a simulator sketch that is designed to follow the simulator’s programming steps – it is NOT A PFD. You can (and should have) generate a PFD such as I did. You also could have done the very same thing I did in 45 minutes. It is simple, straightforward, and with the process data tells the reader all that is needed to start the formal calculated process design of the cooler-condenser. You obviously have opted not to do that and you have not responded to my questions and recommendations. That, in my humble opinion, is why you are confused – by your own admission. This cooler-condenser design is a very easy and fun project that is being wasted because of a lack of attention span and willingness to heed experience and recommendations.
You have not stressed me with all the paperwork related to your part I of the project. As I pointed out, all that information is useless to resolving the topic at hand: the process design of a gas cooler-condenser. Your project Part I is not relevant to what you have described as your assignment. Your assignment, as described by you, is a rather simple and direct one. I hope that you can see and admit that and that we can help you in reviewing, critiquing, and commenting on your generated project work such as the PFD, the specification sheet, and your generated, logical calculations.
Do not despair; as I stated, this should be a fun project and if you have studied the material thoroughly in the past you should be prepared to do a good job.
#20
Posted 24 March 2012 - 06:20 AM
Woooh hold your horses
- You are cooling your process from 500 °C to 20 °C. You should consider two separate condensers one running on cooling water and another on chilled to give a more practical design.
- However You are coming up with a 44 m tube length for the jacketed pipe heat excanger you are considering.. Note that with these lengths you are probably looking at many tubes that fit into a design similar to shell and tube heat exchanger with cooling water on shell side or you are looking at something similar to a convection section of a fired heater with flue gas on box side.
- Also note that you have missed adding heat of condensation load. Use the latent heat of water and its mass flow to calculate it and add to the total duty.
- Also very important: you came up with heat loads by manually inputting mass flow for both streams thats...wrong. For flue do that (plus point 3 above). for cooling water use the duty of flue gas, put in equation q = (m)(cp)(dt) and come up with mass flow . (don’t use that goal seek option in your sheet)
- Your cell in which you calculated length is not clear. I am seeing LN in there; what have you done there? This one should be a simple one......
#21
Posted 26 March 2012 - 08:42 AM
#22
Posted 10 April 2012 - 02:54 PM
Happy easter. I have followed your instruction about the steps and also about getting the kerns book. I do have the book and i have read it. I have gone through example in the book as you have recommended. The section you recommended was for single vapour. So i went through the mixed vapour section rather than single vapour as i have mixed gases going into the condenser. The examples in the book did mention about iterating to derive the bubble point and dew point in order to get the weighted change in temperature, which until then i cannot calculate my Heat duty and follow the condenser design through. Another issue is the fact that i cannot find Antoine coefficient for the gases and temperature am dealing with. I have tried perry's and all its mentioning is about hydrocarbon's. I am confused on how to get the vapour pressure of each gas in the mixture, vapour pressure of each pure component (gas), mole fraction of the liquid as that cannot be calculated without the vapour pressures. Most of the books i read had a data for K-value for each component which is in graphical form. All text books including kern only had for hydrocarbons which is different from mine.
I am also not sure of the method am using for this design which is the one you recommended. Most books including Kern talked about examples of vapour coming from a distillation column which is very common in the oil industries but in my own case its a Nuclear plant where waste gases are coming from 2 furnaces. I have attached the excel sheet of what i have done but am stuck as i cannot calculate the vapour pressures and K values.
The double pipe condenser is very near to the end of the ventilation system on the
plant. The only thing between the outlet of the condenser and the
ventilation fan will be a HEPA filter. The fan will typically pull a vacuum
of about 35mbar and a HEPA filter will have a dP of about 25mbar. So the exit on the condenser will be at -10mbar g. Given the remaining 10mbar
will have to drive the whole ventilation system right back to the
dissolver, so therefore, I would not have a dP > 5mbar across the vapour side.
Please have a look at the labelled spread sheet 1. The sheet 2 were the values for K, Fz and etc i derived before correcting the mass balance (at the bottom of sheet 2, titled Furnace condenser). As soon as the mass balance was corrected i could not derive the vapour pressures and X values.
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Smr Reformer Tube Hot BandStarted by Guest_kaidlut_* , 07 Aug 2025 |
