i want to Link my hysys simulation to excel, so i can work in excel too. can you help me, please?? what should i do?
thanks...
Posted 12 April 2012 - 04:29 AM
Posted 12 April 2012 - 09:52 PM
Posted 15 May 2012 - 05:09 AM
Posted 06 November 2012 - 08:25 AM
Posted 06 November 2012 - 02:03 PM
Posted 08 November 2012 - 05:13 AM
Posted 15 November 2012 - 02:38 PM
Posted 15 November 2012 - 07:46 PM
Something that you rely heavily on when linking Hysys with Excel, or making Excel much more functional for that matter.What is VBA Code?
Posted 15 November 2012 - 10:02 PM
Posted 12 December 2012 - 02:19 AM
Posted 28 February 2013 - 01:22 AM
savarove, you may use this code to obtain molar composition
Dim ambildata As ProcessStream, item as integer
Set ambildata = simCase.Flowsheet.MaterialStreams.ITEM(“stream1”)
For ITEM = 1 To 24 ' i have 24 components on "stream1"
Cells(2, ITEM).value
= ambildata.ComponentMolarFractionValue(ITEM - 1)
Next ITEM
hope this help, I'm sorry for late respond.
Alex
Posted 04 March 2013 - 12:44 AM
I think you forgot to mention these on your post:
1. You need to use VBA to execute that
2. You did not include the initialization of simCase, which should be either a class that belongs to Hysys.SimulationCase or Hysys.Application
Posted 04 March 2013 - 04:17 AM
Hysys Stream Reporter can be used generate the data in Excel. This utility can be found in the internet or will be given as part hysys basic training. If you have token system, you can use aspen simulation work book to link the data to excel.
Posted 11 March 2013 - 11:30 PM
I think VBA is necessary for hysys link to excel
Posted 12 March 2013 - 09:13 AM
Wow. That seems a lot more difficult than it is in ProMax. In ProMax, you just right click on on any value and select export to excel.
Or you can use the scenario tool demonstrated here:
Posted 12 March 2013 - 06:54 PM
ProMax is run with Visio, so I suppose exporting to Excel would be easier than with Hysys
Posted 07 September 2013 - 05:08 AM
Hi everybody ;
Please try the following steps to link Hysys to Excel:
Now if you change for example the related temperature on your simulation case you can see that the value of mass density will change in the excel sheet. By this method you can link all your required data to the excel.
I hope that this can help you.
regards.
Posted 26 September 2013 - 04:02 AM
Dear all,
i am back with the exporting composition to hysys.
I am getting an error saying object does not support this propriety or method.
Attached is the code.
Option Explicit
Posted 26 September 2013 - 10:56 PM
Before you can import stream compositions, you must set the array in HYSYS by setting each component flow to 0. Then all will work well. There may be an example on the AspenTech site.
Posted 27 September 2013 - 05:26 AM
Thanks Bod,
I was making some mistakes on the code.
It is now running.
Sacarove
Posted 30 September 2013 - 04:23 AM
I am having an Out of range error on the code below:
Posted 18 November 2013 - 09:19 AM
Dear all,
i want to fetch a value from the spreadsheet I have in hysys.
How the vba code would look like?
Sacarove
Posted 12 December 2013 - 03:30 AM
Thank you thank you thank you! I was getting a just a little bit annoyed because I couldn't get the values from my case file to update on my aspen workbook in excel, this has helped me a lot! ![]()
Hi everybody ;
- open your simulation case
- open a new excel sheet
- copy the value to be linked to excel (for example the mass density) you can use (Ctrl+C)
- go to the new excel sheet, click on the right button of the mouse and select special paste.
- the table of special paste will appear; select coller avec liaison (or paste with link) and select text, then OK.
regards.
Posted 15 December 2013 - 06:02 AM
hi all, please does any one have a code that i can use to generate a user defined module for a membrane in Aspen plus. i am stocked and can make much progress with my simulation.
Posted 03 April 2015 - 04:01 AM
Hi everybody ;
regards.
Hello everybody,
Do you know how to export data from excel to HYSYS, as well?
Thank you very much,
Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
