MDEA Reboiler Duty Calculation
Started by vista, Jun 12 2012 02:32 AM
10 replies to this topic
Posted 12 June 2012 - 02:32 AM
hi every1,
can anyboby tell me how can i calculate the reboiler duty for a gas treatment plant using MDEA?
I need the basic guidelines and formulae
i only have the parameters of reboiler operation with me right now
Posted 12 June 2012 - 06:17 AM
The basic equation for the reboiler is Q = UA(delta T)LM. Use consistant units.
Posted 12 June 2012 - 06:46 AM
vista,
You might like to have a look at the following:
http://msdssearch.do...fromPage=GetDoc
http://articles.comp...g-amine?start=5
Posted 13 June 2012 - 07:32 AM
Vista:
You are having problems getting your query resolved because you haven't furnished any required and necessary basic data regarding your MDEA reboiler. Now you return with the additional, important detail that yours is a direct-fired reboiler. You totally omitted that very important detail in your original post where you should have given ALL of the basic data - including a sketch.
I have had many years of amine unit experience - in design, installation, operation, and modifications. I have a very good idea of what I believe you have in front of you. But I can't guess what it is that you specifically want (or need) to do: do you want to re-design the tube bundle? do you simply want to understand how to design it? do you need to replace the bundle?
Who designed and built your unit? how long has it operated? What is its capacity (rich MDEA circulation)? What is the MDEA concentration? What acid gases are you removing and what is the composition of the feed gas to the MDEA absorber? If this is an existing unit, then you should have a detailed P&ID and you should supply us with a copy. With this infomation and background we can start to answer your specific questions.
I know how the direct-fired tube bundle is designed and built. I've done it before. But I won't respond to a query that has no required basic data. Help us help you.
Posted 14 June 2012 - 01:11 AM
thnax for your response;
well i m doing internship at gas processing facility comprising of sweetning unit using MDEA...here partial removal of CO2 and complete H2S removal is carried out..lean amine circulation is 85 USGPM..i only want to know how can i calculate the amount of heat transfered during an hour (reboiler duty)...what i need to know before calculating reboiler duty?...the design duty is 5.1 MMBTU/hr and flux rate 7500 BTU/hr/ft2 with fire tube area 680 ft2....i need to calculate the duty for the particular hour
Posted 14 June 2012 - 04:48 AM
Posted 15 June 2012 - 09:27 AM
Vista:
Refer to the attached Rev1 of your workbook and to the worksheet where I have depicted the PFD of your unit and made the comments on how to calculate the reboiler duty.
You can obtain MDEA data and calculation examples from such literature sources as:
- John Campbell's Gas Processing books;
- The GPSA Engineering Databook;
- Kohl & Reisenfeld's book, "Gas Purification".
Posted 16 June 2012 - 03:07 AM
Art Montemayer:
Thanks alot for your useful comments and guidance. that is really helpful. such type of detailed response is really appreciating...
one thing i would like to ask again is that, as you have mentioned in your attached workbook, that i can calculate the reboiler duty by fuel gas firing rate..now the issue is that we only have a pressure regulator installed in fuel gas line, this regulator is used to increase or decrease the pressure of the fuel gas as per requirement of reboiler temperature...can you please tell me how can i calculate the firing rate with this instrumentation....
you guidance at this querry will also be very helpful for me in better understanding of reboiler operation...
#10
Posted 16 June 2012 - 08:43 AM
Vista:
If you have no direct reading flow meter on your fuel gas supply to the direct-fired reboiler, you obviously have a cheap, “low-capital investment” type of installation for your unit. That brings back a lot of memories for me because that was the case in many of my early engineering projects when I was your age. I would think you have a means of knowing the fuel gas being consumed in your unit because of the prices of fuel today and the drive to account for all flue gases put into the atmosphere. But if you can’t obtain the fuel gas firing rate, that’s OK. You still have another method:
In Kohl & Riesenfeld’s book, “Gas Purification”, 3rd Edition, Chapter 2: “Ethanolamines for Hydrogen Sulfide and Carbon Dioxide Removal”, pages 74 & 75, you will find specific instructions on how to estimate the heat load in an amine reboiler.
“Sufficient heat must be supplied to:
Always remember the this basic advice given to me by mentor many, many years ago: “When in doubt, always generate a heat and mass balance”.
Kohl and Riesenfeld give the necessary data on heat of reaction for MDEA and furnish an academic discussion on “Reflux” use in the Stripper (which I have always criticized and found lacking in practical and hands-on engineering knowledge). I have never used Reflux in my acid gas units and found that it isn’t required in a properly designed unit.
- Provide sensible heat to raise the temperature of the feed rich solution to that of the lean solution leaving the reboiler;
- Provide heat of reaction to dissociate the amine acid-gas compounds; and,
- Evaporate the water that leaves the stripping section of the Stripper as steam with the acid gas.”
#11
Posted 17 June 2012 - 01:33 AM
Art Montemayor:
thanks again...i will be back with my calculation results of heat balancing very soon...
Phe As ReboilerStarted by Guest_Chemeng40_* , 20 Feb 2025 |
![]() How To Replace Existing Reboiler With A Thermosyphon Reboiler In HysysStarted by Guest_tomr91_* , 04 Feb 2025 |
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
