What is the different between full-conversion and semi-conversion refinery in terms of type of process units and the refined products?
Difference Between Full-Conversion And Semi-Conversion Refinery
Started by go-fish, Jun 25 2012 11:44 AM
Posted 25 June 2012 - 11:44 AM
Posted 27 June 2012 - 09:46 PM
I don't know the concepts you mention.
The 3 types of refineries I know are defined as follows:
- simple (or hydroskimming) refinery: crude distillation, catalytic reforming and hydrotreating
- complex refinery: simple + vacuum distillation, catalytic cracker, hydrocracker, alkylation unit and gas plant
- very complex refinery: complex + a coker
Edited by sheiko, 27 June 2012 - 09:52 PM.
Posted 07 July 2012 - 02:33 AM
Basically, in a full-conversion refinery you don't produce fuel oil at all while in a semi-conversion one you only reduce the quantity of fuel oil (bottom-of-the-barrell) that is present in the crude (after the Vacuum Distillation Unit).
Various options are available to convert the BOB fraction; mainly:
- Coking: it is the most applied technology, especially in the USA. It produces a lot of gas and gasoline, little distillates and coke as by-products.
- Vacuum Residue Hydrocracking: it is a very severe operation, using Hydrogen at very high pressure (200-250 bar). It maximizes the production of middle distillates.
What Is The Difference Between Api 521 Sixth Edition & Seventh EdiStarted by Guest_Murtaza Lashkerwala_* , 13 May 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
Conversion Of M3 Of Natural Gas To M3 Of LngStarted by Guest_sachico28_* , 30 Sep 2023 |
