Multiphase Adiabatic Flash
Posted 27 July 2012 - 03:09 AM
I am modeling a discharge through a orifice plate with Prode Properties, generally I model this operation as adiabatic flash but I see that there is also a constant energy flash,
Prode includes several flash operations which support multiphase,
among others there are
HPF() for specified enthalpy and pressure
SPF() for specified entropy and pressure
EPF() which solves the constant energy flash operation
I know little of constant energy flash,
when should I use this operation ?
Posted 27 July 2012 - 04:21 AM
the EPF flash operation solves the constant energy flash where energy is calculated as sum of enthalpy and kinetic energy,
this method permits to model adiabatic expansions where the contribute of kinetic energy cannot be neglected,
you may consider for example the discharge from a stagnation point (vessel internal) to orifice and from orifice to atmosphere
Posted 31 July 2012 - 09:22 AM
what about to model a safety valve ?
Do you suggest HPF() adiabatic flash ?
Posted 01 August 2012 - 09:01 AM
for gas/ vapors in some cases I prefer a direct (numerical) integration of nozzle mass flux equation with multiple isentropic flashes, with Prode Properties working within Excel it's very simple with the macro =SPF() which solves the pressure-entropy flash specifications.
This kind of flexibility permits to solve even the most difficult cases...
Posted 12 December 2012 - 03:23 AM
energy balance gives
Hin*1/2*Vin^2 = Hout+1/2*Vout^2
the method EPF() takes in account the contribute of Vin and Vout
for a nozzle you should consider the method ISPF() which allows to solve a isentropic operation with HEM, HNE, HNE-DS and NHNE models
Posted 04 March 2013 - 06:39 AM
thanks,
I have found that Prode Properties distribution includes a Excel page to design/rate pressure safety valves with critical or two-phase flow with
-HEM (Homogeneous Equilibrium Model)
-HNE (Homogeneous Non-Equilibrium) with boiling de...lay and gas-liquid split contributes
-HNE-DS (Homogeneous Non-Equilibrium)
-NHNE (Non-Homogeneous Non-Equilibrium)
so a whole range of models is available
Posted 31 July 2013 - 04:01 AM
Kerosene Flash Point TroubleshootingStarted by Guest_zuberattan_* , 25 Oct 2009 |
Flash Seperation For N-Butane IsomerizationStarted by Guest_CHEMICAL_LOVER_* , 04 Dec 2024 |
Flash Tower With Tray In Deoiling Of Wax?Started by Guest_AnbIran_* , 01 Jul 2024 |
Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
