Can anyone tell me how to calculate Cv for valve? I have a control valve that is 100% open and I am trying to figure out whether or not this valve is undersized by comparing design value. This valve controls the flow rate of IP steam.
Thank you.
Control Valve Calculation
Started by bosun, Aug 29 2012 08:07 PM
Posted 29 August 2012 - 08:07 PM
Posted 29 August 2012 - 08:19 PM
Hi!
I think this is related to your query on the heat exchangers in your SRU.
To answer your question, refer to this link for Cv calculation although I have to admit I haven't calculated Cv's manually for a long time since this is easily done with software nowadays.
Posted 30 August 2012 - 08:33 AM
The Cv for control valve should be recorded in the documentation for the valve. A lot of times the Cv for a control valve is listed on a metal tag that is attached to the valve.
Posted 30 August 2012 - 01:47 PM
Posted 31 August 2012 - 02:40 AM
Bosun,
Here are some useful resources.Hope you find interesting.
Below you can find Training Courses of Control Valves.
http://www.pro-quip....ction/SS_03.pdf
http://www.idc-onlin...ntrolValves.pdf
http://www.idc-onlin...neering/caq.pdf
http://chemical.eng....ALVE_Theory.pdf
http://www.tescom-eu...ow_Formulas.pdf
http://frame.leser.c...en_7-Sizing.pdf
http://www.pipeflow....efficients1.htm
http://www.documenta...1798x012_11.pdf
http://www.circle-se...lve-sizings.pdf
http://www.metropac....DFs/77-1141.pdf
http://www.sbt.sieme...on/15370186.pdf
http://www.kele.com/...html#steamvalve
http://www.documenta...1798x012_02.pdf
http://blackmonk.co....-control-valve/
http://facstaff.cbu....ures/valve.html
Shivshankar
Shivshankar
Edited by Shivshankar, 04 September 2012 - 12:29 AM.
Two Phase Reverse Flow -Psv Sizing For Check Valve Failure CaseStarted by Guest_namita.modak1_* , Yesterday, 08:15 AM |
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
