I was reading through a design philosophy the other day for an HFO Tank Farm for a power station and it had referenced NFPA 15 and IP 1089 Part 19.
I have 2 questions;
1. When calculating the water requirements it had assumed that one of the tanks was on fire and required the water coverage stipulated by NFPA 15 of 10.2 Lpm/m2. All adjacent tanks however were calculated on a flow rate of 2 Lpm/m2. I have never seen this in NFPA 15 (please correct me if I am wrong) so assume that it must be in IP 1089 Part 19. I have tried to find this standard online but have failed which is why I have posted this. Can someone please confirm and shed some light or even advise where I can purchase a soft copy of this standard?
2. In the design philosophy no water was required for potential pool fire in the bund area however the way I understand NFPA 15 is that this is a requirement. In section 7.3.3 it mentions water spray systems designed to control pool fires resulting from flammable or combustible liquid spill fires which to me would appear to apply to bunded areas in a tank farm. What however is unclear is why the water requirements would be greater on the concrete bund area (12.2 Lpm/m2) than they would on the on the tank itself has caused me to doubt myself. Am I misinterpreting this? What would apply to water volume requirements for bunded areas?
I look forward to your responses.
Ip 1089 Part 19 Fire Precautions At Refineries And Bulk Storage Instal
Started by Leinster, Aug 30 2012 11:32 PM
No replies to this topic
Posted 30 August 2012 - 11:32 PM
Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , Yesterday, 08:54 AM |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Butadiene StorageStarted by Guest_Mirzazada_* , 27 Mar 2021 |
Psv Fire Case Relief Load CalculationStarted by Guest_mahmooddalvi09_* , 21 Feb 2024 |
Green Diesel StorageStarted by Guest_Lucianaa_* , 16 Feb 2024 |
