Relief Valve Calculations
#1 nmh
nmh
  • 10 posts
Posted 15 March 2013 - 03:25 AM
Dear Experts,
I have a question regarding relief valve calculation. My relief valve is set at 200 barg for hydrogen service and relief valve outlet pressure is 1.5 bara.  I want to calculate the flow through the valve, for flow calculations I would like to know which pressure (for corresponding hydrogen density) should I consider to calculate the flow in case of relief scenario.
Many thanks.
nmh
#2 paulhorth
paulhorth
  • 396 posts
Posted 15 March 2013 - 05:41 AM
This question shows a depth of ignorance which is rather scary.
Please can you first tell us what equation you are intending to use to calculate your relief valve flowrate?
 But first I would advise that you make some effort to read up about the subject of compressible flow and critical flow.
Paul
#3 satendra.deshmukh
satendra.deshmukh
  • 18 posts
Posted 15 March 2013 - 10:23 AM
it depends on which scenario you are performing on that relief device..
#4 latexman
  • 1,894 posts
Posted 15 March 2013 - 10:39 AM   Best Answer
In the sizing equations I am familiar with, the upstream density (i.e. upstream pressure) is used, however the flow is also dependent on the pressure drop (i.e. upstream pressure - nozzle exit pressure), so you must consider both upstream and downstream pressure to determine the type of flow (non-compressible, compressible, sonic, etc.) and the rate of flow.
#5 nmh
nmh
  • 10 posts
Posted 16 March 2013 - 02:22 AM
Latexman,
Thank you for your reply.
nmh
#6 breizh
  • 6,940 posts
Posted 16 March 2013 - 02:37 AM
nmh .
It may be good for you to read these documents .
Hope this helps you out .
Edited by breizh, 16 March 2013 - 02:38 AM.
#7 fallah
  • 5,026 posts
Posted 16 March 2013 - 02:53 AM
nmh,
You are faced with a critical flow, then you should just consider 220 barg (for fire case 1.21*220 barg) as upstream relieving pressure to calculate the flow through the PSV...
