Hi, We want to by Hydrogen Recycle gas Compressor( Reciprocating Type, Electric Motor driven) for our Naphtha reformer unit ( 2500BPD). we want use the new compressor for both reformer unit and Naphtha Hydrotreater unit. I need prepare a full specification sheet for sending to vendor. (operating capacity 3-16 mmscfd (75% pure Hydrogen gas, Molecular weight 11, compression ratio require 2/1, operating suction pressure 245psig, suction pressure veriable(100-250 psig )). Can anybody help me about preparing specification sheet for vendor. how to format such kind of sheet.
Hydrogen Recycle Compressor Purchase Specification Sheet
Posted 21 October 2013 - 12:40 AM
Posted 21 October 2013 - 01:23 AM
Miraz,
Appendix A of API STD 618 (Reciprocating Compressors for Petroleum, Chemical, and Gas Industry Service) has typical datasheet for Reciprocating compressors. It can be configured as an excel datasheet and used for submitting to the vendor to get quotes.
Posted 21 October 2013 - 10:29 AM
Miraz:
As Ankur has stated, what you need is an API 618 Data Sheet(s) in order to fully specify the conditions and equipment that you require from the potential vendors.
I am attaching an Excel version of the 1995 API 618 edition for your use. This should be more than enough to fully describe what you intend to buy. Note the details that are required to fully describe the scope of work and the machine to be supplied.
This document should serve as the basis of your ultimate purchase and all revisions subsequent to the issue of the tender should be detailed on this copy. You should always specify the initial suction and ultimate final discharge pressures to the supplier – and not the “compression ratio”. It is not possible to understand what you have written as the “compression ratio”. You state the operating suction condition pressure will be 245 psig. Does this mean the operating discharge pressure should be 504.7 psig? You should always indicate your pressures in absolute units (psia) unless you state what the design atmospheric pressure is where the compressor will operate. You also indicate that the suction pressure will vary. You should state what are the expected (and desired) suction design pressures (and temperatures) as well as any variances in the discharge pressure. Allow the supplier to explain or comment on how it is proposed to design the proposed machine to handle the different operating conditions. For this purpose you should create various cases showing the different operating conditions.
API 618 1995 Compressor Data Sheets Rev1.xlsx 1.64MB
142 downloads
Posted 30 October 2013 - 04:57 AM
Dear Sirs,
Thank you for helping me. The given specification sheet was very helpful to me. one thing I should mentioned earlier that this compressor will be used to circulate gas through out a process section and a partial flow through another section for purging. Goal is not to store gases in a system or high pressure vessel. and I made mistake, compression ratio will be 1.4 . May be I am wrong, but for Recycle compressor- compression ratio is necessary (Process requirement).
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Igv Control For CompressorStarted by Guest_Lyne_* , 30 Aug 2025 |
