We have a two-stage air compressor and a cold stream with which we have the potential to exchange heat and reduce the inlet air temperature. Suppose the inlet air conditions at atmospheric and we can bring about a change of 10 deg C in the inlet temperature. How significant will be the reduction in the power consumption. Will it be worth installing a heat exchanger and its auxiliaries.?
I have attached the excel sheet which which gives us the indication of the polytropic index, we assume it constant and estimate the exit temperature and hence the work reduction..it does not show any significant results Is it the Installed compressor efficiency.xlsx 152.71KB 12 downloadscorrect approach?
