Hello..
I have a design problem for designing a shell and tube heat exchanger for heating ethylene gas with superheated steam:
Shell side: ethylene gas at 32 bar to be heated from 22 Celsius to 65 Celsius, flow rate 340724.7 kg/h.
Tube side: steam at 5 bar it will be cooled and condensed ( saturation temperature of water at 5 bar is 151) from 237 Celsius to 151 Celsius, flow rate 14037 kg/h
I did all the calculation it was easy but the problem I don't know how to calculate the heat transfer coefficient for the condensing steam in the tubes because all the books and topics in the web are discussing the condensation of saturated fluids not superheated. This heat exchanger is existing in a petrochemical plant and it is my study case to be submitted for my chemical engineering project class. All what I have to do is to design a heat exchanger similar to the existing one starting from scratch.
more information:
It is a BJS TEMA type
with 1 shell pass and 2 tube passes
heat transfer area is 200 m2
no of tubes 584
tube length 6 m
