What is the difference between Pipeline Pumps and other Pumps?
As Per API 14c SDV should be provided in the upstream of Pipeline pumps and for other pump there is no need of SDV. why?
Posted 05 August 2014 - 01:45 AM
Posted 05 August 2014 - 02:37 AM
Gany,
Providing SDV upstream of a pump is a matter of safety issue and may be considered either for plant or for pipeline pumps....
Posted 05 August 2014 - 06:50 AM
i am unable to understand your point. can u please explain detail?
Posted 05 August 2014 - 12:37 PM
Gany,
It means as per the requirement a SDV can be provided either at the upstream of a pipeline pumps or at the upstream of a process pump inside the plant. Please let's know the statement from API 14C mentioned in your first post is in which part of this recommended practice...
Wafer Check ValveStarted by Guest_Ali4269278331_* , Yesterday, 01:31 PM |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
