Is it possible to calculate the fluid temperature specifically hydrogen peroxide (30%) with only these specs: The tank is light blue exterior painted over 1/4" steel. I have the ambient temperatures and humidity, heat transfer coefficients for the steel, and assuming a full clear sunny day with 5 hours of incident sun exposure can I make a guess at what the hydrogen peroxide temperature can be? Also does anyone know what the induction period of hydrogen peroxide is if the temperature exceeded the self accelerating decomposition temperature? What I want to know is if heat from the sun and ambient temperatures can cause a tank of hydrogen peroxide(30%) to explode. Thanks for anyone who can help.
Calculating Temperature Of Fluid In A Steel Tank
Started by ohmyscience, Aug 08 2014 08:22 PM
Posted 08 August 2014 - 08:22 PM
Posted 30 August 2014 - 10:02 PM
http://www.cefic.org...ideline2005.pdf
Consider this resource or contact vendors to support your work .
I've been using H2O2 70% for many years without any trouble , following the guideline above , with a continuous monitoring of the temperature and possibility to introduce a massive quantity of "good quality "water in case of run away reaction .
Hope this helps
Edited by breizh, 30 August 2014 - 11:43 PM.
Buffer Tank Sizing Upstream Screw CompressorStarted by Guest_Process_1601_* , Yesterday, 11:41 AM |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
