can anyone provide me with complete process description for oil refining process and a PFD and PID ???
Refining Process
Posted 29 August 2014 - 06:15 PM
Posted 29 August 2014 - 07:50 PM
The process description and accompanying flow diagrams can vary somewhat due to the type of crude oil feedstock (and other liquids received as feed) and then also on the mix of products desired. These factors can effect the types of process units (refining process technologies) that are necessary in between the feeds and the products.
Posted 29 August 2014 - 08:45 PM
Probably good to read .
good luck .
Posted 30 August 2014 - 04:31 PM
But i wonder if anyone can still provide me with a PFD and a PID for the refinery he works at and just mention the engineering vendor....
Posted 31 August 2014 - 04:49 AM
A complete refinery, including OSBL and utilities, has more than a thousand pieces of equipment, dozens of PFD's and hundreds of P&ID's.
Refineries are built by engineering contractors like:
AMEC
Bechtel
CB&I
Fluor
Foster Wheeler
Jacobs
Snamprogetti
Technip
and several more.
Posted 31 August 2014 - 10:08 PM
You can ask for these, as you did, but no one will supply you with them. The items are all proprietary and the owners spent $millions to develop them.
Ammonium Sulfate Process SimulationStarted by Guest_amir55261_* , 06 Apr 2024 |
Mtbe Process Flow Diagram Master Thesis.Started by Guest_sayoub_* , 15 Feb 2024 |
Let Down Vessel In Methanol ProcessStarted by Guest_Manue_* , 21 Mar 2024 |
Electrical Inputs From ProcessStarted by Guest_Chari_* , 06 Feb 2024 |
Recycling Of Working Solution In The Anthraquinone ProcessStarted by Guest_Has2riasat_* , 01 Feb 2024 |
