Hi all,
I am looking for a effciency range for pump selection below which pump can not be selected.
Efficiency for pumps i am looking for are
1. Centrifugal Pump.
2. Positive displacemnt pump.
Thanks and regards,
Raj Ghosh
Posted 15 September 2014 - 02:34 AM
Hi all,
Thanks and regards,
Raj Ghosh
Posted 15 September 2014 - 04:06 AM
Raj,
The efficiency range of such pumps is normally from 15% to over 90%....
Posted 15 September 2014 - 07:02 AM
For centrifugal It depends, between other things, on the size of the pump.
Small pumps (till 100m³/h) - usually 50-65%
Regular pumps (100-1000m³/h - usually 75%
Big pumps (>1000m³/h) - usually 75-82%
You can find in the internet lots of pump curves. Try flowserve.com.
Turbine Driven PumpStarted by Guest_Rahimzadeh_* , 27 Apr 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
