Wattson Characterization Factor Of Fuel Oil
Started by brenan, Oct 02 2014 12:15 PM
Posted 02 October 2014 - 12:15 PM
Hi, friends:
To find the factor Wattson characterizationv(Kw) of petroleum fractions, the points of the ASTM D 86 distillation and specific gravity are necessary. These data are readily available in the laboratory. My consulting the forum is like finding the Kw for fuel oil (bottom product of primary distillation) as being a heavy product is not makes the ASTM D86. I will appreciate your comments.
Thank you
Brenan Figueroa
Posted 02 October 2014 - 10:21 PM
UOP 375 gives a method to calculate UOP K values from Kin Vis and Density. Kin Vis at 100, 122 and 210 (any one) can be used.
Posted 15 February 2015 - 08:45 PM
Dear Brenan,
You can check the textbook: Riazi, Characterization and Properties of Petroleum Fractions, p.70-71. The nomograph gives the relation between kynematic viscosity and Kw, and there are the equations for to do a spreadsheet.
Napo.
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
Predicting Fouling Factor In ReboilersStarted by Guest_ProcessEng_12_* , 12 Aug 2021 |
Hydrogen Fuel CellStarted by Guest_rednaxela_* , 09 Mar 2023 |
Diesel FuelStarted by Guest_CHEMSTRONG_* , 24 Feb 2022 |
Presence Of Elemental Sulphur (Solid Phase) In The Pcv Of The Fuel GasStarted by Guest_husseinelgenedy_* , 20 Aug 2022 |
