Dear Experts
I am new to this process engineers forum.
I am currently working on a mass and energy balance for a calcite type limestone rotary kiln with preheating tower. In the past, I did material-heat balances to calculate heat loss, unknown quantities. But I never done a M&E to calculate the unknown temperature. I am looking forward to seek some help to determine the methodology to calculate temperature of solid material from heat balance calculations.
I have attached a simple block diagram with parameters for your reference.
My main objective is to estimate the temperature of lime stone entering into the kiln from pre-heater & temperature of air entering the kiln.
In our plant, we don't have facility to take sample out of tower or no sample point between kiln and pre-heater.
So rate of conversion inside pre-heater is unknown and also the temperature of solid material,composition is unknown.
Please let me know if I can really find out of temperature of solid materials from heat balance. It looks like there are more unknowns than equations.
It would be great if an expert can give me the methodology to solve the unknowns.
Unknowns:
1. Temperature of material coming out of kiln to cooler (solid material not gas) ?
2. Secondary air temperature above cooler and below burner is unknown?
3. Stone feed temperature from pre-heater to kiln is unknown? I have to calculate by assuming some conversion and I don't know how much to assume (should i assume 0% or 10% or 20% conversion inside pre-heater)
4. Heat losses around pre-heater is unknown , heat loss around cooler unknown(may be I can assume no heat loss in cooler), kiln shell loss was measured using shell scan temperature measurement.
knowns:
1. Production data is known based on tonnes- I calculated the feed rate
2. Fuel flow rates (coal,gas)are known- I can work out stoichiometric air requirements and flue gas emissions.
3.Temperature of raw materials, fuel from the plant such as stone feed at ambient conditions, fuels at standard condition for gas , for coal- temperature is known.
4. Primary air supplied by fan, cooler air supplied by fan is known.
5. Oxygen , CO at Kiln inlet and pre-heater exit is known.
6.Dust loss is assumed
7. Feed end temperature (dust, flue gas from kiln outlet to pre-heater in) is known
8. From material balance - I can calculate false air leakage quantity.
9.composition of raw materials, products ,fuels are known.
Kind regards
sen
