Any one please brief me about Self regulating valve.
Is Sizing of Self regulating valve is same control valve as per ISA_750101
Posted 09 February 2015 - 05:45 AM
Posted 09 February 2015 - 02:06 PM
As far I know
size the self regulating valve in the same way as control valve. Fill the data sheet with Min/ normal / Max process condition and title will be self valve rather than control valve.
Posted 17 February 2015 - 01:54 AM
Thanks for reply and clarification but i have one query regarding self regulating valve.
As self regulation valve work on some set pressure, So what is criteria for set pressure of regulating valve.
Posted 17 February 2015 - 02:35 AM
What is criteria for set pressure of regulating valve?
-Process requirement and/or mechanical limitations...
Posted 17 February 2015 - 06:55 AM
Dear fallah,
Its is set pressure of self regulating PCV. And it is regarding to process requirement so that pressure at demand point shall not be more than require.
Iam preparing a datasheet for self regulating valve ,in which i required to mention set pressure (Upstream pressure) of valve.
Posted 17 February 2015 - 07:22 AM
If the pressure at demand point shall not be more than required, then the pressure of PCV downstream should be set at prespecified value...
Anyway if you can upload a simple sketch of the system it might you can get better reply...
Wafer Check ValveStarted by Guest_Ali4269278331_* , 24 Apr 2024 |
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
