Pump slip for rotary PD pumps is a phenomena where the pump theoretical displacement capacity is reduced due to a combination of decrease in viscosity and increase in discharge pressure.
I would like to know the method for calculating the decrease in capacity of the pump for a rotary 2-screw pump which has been specified for pumping 2 different products with different viscosities. Let us say that one product has a viscosity of 380 cSt and is the design case specified to the pump manufacturer for a given differential pressure and flow rate. The pump is a fixed speed pump. Now the same pump is required to be used for pumping another product with a lower viscosity of 22 cSt.
How do I calculate the flow rate for the second case with the reduced viscosity considering "slip" playing a role in changing the pump capacity? Are there any formulas or equations for doing such a calculation?
Edited by ankur2061, 14 February 2015 - 04:07 AM.
