Steam Calculations
#1 gajus21
gajus21
  • 6 posts
Posted 26 February 2015 - 03:59 AM
Welcome
I have a question: how to calculate the amount of carbon needed to recive 800 Mg / h steam.
Parameters: Water: 180 ° C, 14 MPa,
Steam: 540oC, 9,6MPa
Coal calorific value: 23 000 kJ / kg
I tried to count from the enthalpy difference of steam and water, as well as evaporation + heated to the desired temperature, but I recive very differents values.
Total heat needed to warm to that temperature. 2 176 160 000 kJ ->95 Mg carbon
Enthalpy difference: 1 556 800 000 kJ ->68Mg carbon
I'll be very grateful for Your help
#2 Cooks
Cooks
  • 16 posts
Posted 26 February 2015 - 10:57 PM
Honestly, your question is unclear.
Be clearer so one can point you aright
#3 gajus21
gajus21
  • 6 posts
Posted 27 February 2015 - 04:57 AM
Honestly there is more than enough informations. I found informacion how to calculate this maybe someone will be needed it
BQW = D(ip – iw) + SQS
B - mass carbon
Qw - calorific value
D - mass of steam
ip and iw - enthalpy
SQS - lost of heat other
There was only one thing to check: enthalpy steam and water
#4 gegio1960
gegio1960
  • 517 posts
Posted 27 February 2015 - 10:03 AM
with your data and a steam table:
h water @ 180°C & 14 MPa = 182.3 kcal/kg
h steam @ 540°C & 9.6 MPa = 851.7 kcal/kg
coal NHV = 23000 / 4.186 = 5494.5 kcal/kg
DH of the whole process = 800000 * (851.7 - 182.3) = 5.4*10E8 (ideal... you should consider an efficiency)
weight of coal = 5.4*10E8 / 5494.5 / 1000 = 97.5 t .... similar to 95 t of your 1st calculation
#5 gajus21
gajus21
  • 6 posts
Posted 02 March 2015 - 02:13 AM
gegio1960 thank you but I have one more question from where You have taken information aboute steam becasue I can not find parameteter for steam in 540 oC
#6 breizh
  • 6,349 posts
Posted 02 March 2015 - 06:10 AM
http://www2.spiraxsa...eated-steam.asp
Consider this resource and key in your parameters .
#7 gajus21
gajus21
  • 6 posts
Posted 03 March 2015 - 01:28 AM
Thank you
