Dear All
It is a very basic question. However I would like to confirm the method for calculating the Latent heat of vaporization for single component using Hysys.
Steps by Hysys:
1) Take a stream in Hysys and define the composition and Thermodynamic method.
2) define the relieving pressure as Pset X 1.21
3) Define the mass flow rate as 100 or any mass flow rate is ok.
4) Define the vapor fraction as 0 and get the value of mass enthalpy from properties tab for liquid phase and vapor phase
5) Latent heat of vaporization = dew point enthalpy - bubble point enthalpy
= mass enthalpy of vapor phase - mass enthalpy of liquid phase
6) Relieving temperature will be the temperature at relieving pressure and 0 vapor fraction.
I think the above method is correct. However your valuable inputs would be highly appreciated.
Edited by chem_buddy, 10 March 2015 - 12:15 AM.
