I'am designing a biorreactor and I need to design a valve to continuous vent of CO2 and air. But I don't know how sizing the area of vent.
Thanks.
Posted 27 April 2015 - 10:08 AM
Thanks.
Posted 27 April 2015 - 10:41 AM
Nico,
Find the maximum outgoing volumetric flow rate....specify the length and configuration of the vent line....suppose a size for the vent line and calculate the destination pressure based on known flow rate and upstream pressure (reactor design pressure) using gas flow equation. If calculated destination pressure is higher than available value; increase the size and repeat the calculation till the calculated destination pressure to be equal to or lower than available value...
Posted 27 April 2015 - 01:29 PM
Naser,
I calculated the vent area using gas flow equation, but I have some doubts; the design pressure of the reactor is 25 psig + pressure of the column water reactor (the type of reactor is a CSTR ) and the outlet pressure is 1 atm, because it is a atmosferic vent.
So in the gas flow equation, Is the design pressure equal that inlet gas pressure? and Should be atmosferic pressure equal that pressure discharge of gas?
Thanks.
Posted 27 April 2015 - 01:40 PM
Nico,
That pressure is at the bottom of the reactor; but the upstream pressure you should use is 25 psig (pressure at top of the reactor) and destination pressure is 14.7 psig (atmospheric)...
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
