Air Temperature At The Outlet Of A Fan
#1 souha
souha
Posted 28 May 2015 - 02:54 PM
Good evening,
I am sizing a fan for a dry cooling tower . I have an issue when it comes to calculating the temperature at the outlet of the device.
I have the inlet and outlet of the water to be cooled and the design ambiant temperature.
Thank you in advance
#2 ankitg009
ankitg009
  • 33 posts
Posted 28 May 2015 - 11:04 PM
Dear Souha
Consider the attached source. It will be helpful.
#3 breizh
  • 6,356 posts
Posted 29 May 2015 - 02:41 AM
Other good stuff attached .
hope this helps.
#4 srfish
srfish
  • 408 posts
Posted 29 May 2015 - 09:10 AM
You need to know the amount of air flow
First calculate the heat exchanged from the water side.
From heat exchanged and the amount of airflow you can calculate the change in air temperature.
Then using the change in air temperature calculate the outlet temperature.
#5 Bobby Strain
Posted 29 May 2015 - 06:47 PM
What is a dry cooling tower?
#6 breizh
  • 6,356 posts
Posted 30 May 2015 - 03:25 AM
Souha ,
You may consider this Link from GEA where you can get documents and software to support your work.
Another document about air cooler.
Good luck.
http://www.gea-heate...led-condensers/
Edited by breizh, 30 May 2015 - 04:43 AM.
