A liitle bird told me that a valve should be designed to use 10-15% of the total friction loss or 10 psi, which is greater. Could you guys please explain more about that?
What will be happend if I chose the pressure drop of CV smaller than the value ( e.g. 1 psi) Is it related to lift ratio and Cv?
Thank you for your time!
