Dear All
Requesting esteemed members to help in understanding how specific speed of a rotary equipment is defined and what is its physical significance.
Bodhisatya
Posted 23 October 2015 - 11:39 PM
Dear All
Bodhisatya
Posted 24 October 2015 - 02:07 AM
Specific speed of a rotary equipment represents the impeller speed which would develop a head of 1 unit at a flow rate of 1 unit.
Thus:
Ns = N * (Q/Qs)^0.5 / (H/Hs)^0.75
, where:
Ns - specific speed of impeller, rpm
N - speed of impeller, in rpm, at which flow rate is Q and head H;
Qs = 1 unit of flow rate (gpm or m3/hr);
Hs = 1 unit of heat (ft or m);
Of course, Qs and Q, respectively H and Hs units must be the same within the calculation.
Specific speed helps the designer of the equipment in selection of impeller type.
For example, what impeller type to use in order to have the required efficiency, if the application requires a flow rate Q and a pump head H, at a shaft speed N ? Based on the calculated Ns, the designer looks on a diagram an makes a decision.
It is also helpful in determining the impact on pump efficiency in case of changing operating conditions for a pump already in operation.
For further documentation I suggest "H P Bloch - Pump Wisdom Problem Solving for Operators and Specialists" (chapter 1).
Posted 24 October 2015 - 05:03 AM
Variable Speed Pump CurvesStarted by Guest_panagiotis_* , 27 Jan 2024 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
How Does Capacity Control Based On Speed Work For Recip Compressor?Started by Guest_zamakaze_* , 15 Mar 2023 |
Variable Speed Pumps Operation.Started by Guest_panagiotis_* , 11 Oct 2022 |
