Acetic Acid: 0,4222
Water: 0,5474
Ethyl Acetate: 0,0214
Acethaldeyde: 0,0076
Posted 14 January 2016 - 09:00 PM
Acetic Acid: 0,4222
Water: 0,5474
Posted 15 January 2016 - 06:02 AM
Hello Avancini,
Components have the following n.b.p. [°C]: 118, 100, 77 and 21 respectively.
You may use NRTL package with UNIFAC estimation of VLE coeff.
There is only one azeotrope (homogeneous, water-acetate = 40.3 / 59.7 %mol) with n.b.p. of 70.7 °C.
Assume that the objective of the separation is a impurity of 0.001%mol water in bottoms and 0.001%mol acetic acid in distillate.
All these show that:
- an atmospheric column should be provided with a reboiler and a partial condenser (in case of total condenser, the pressure should be increased to around 2.8 barg in order to use cooling water in condenser);
- there is no need for a side draw;
- as specifications you can use the impurities value in distillate and bottoms + either overhead vapors rate, either condenser temperature;
- minimum number of theoretical plates (NTP) is around 25 (you can't use ShortCut Distillation to easily find it because of azeotrope presence, but you can find it by decreasing number of trays until reflux ratio gets very high, hundreds);
- as a start configuration, use 2*25 stages (48 trays + partial condenser + reboiler).
Posted 15 January 2016 - 12:03 PM
I want to correct myself: impurities above should be 0.1%mol, not 0.001 %mol (this is not suitable for a distillation column ).
Also, i forgot to say that position of feed tray should be the 35th tray, numbering from the top.
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Aspen Hysys Training Opportunities For Six Individuals Within Our InduStarted by Guest_Hafiz_Che_* , 30 Apr 2024 |
Calculate Mabp,wabp,cabp And Meabp From Distillation Astm D86 ResultsStarted by Guest_barks123_* , 30 Apr 2024 |
Aspen Plus Convergence ErrorStarted by Guest_NavidJon9_* , 29 Apr 2024 |
Chiller Efficiency Dependence On Cooling Water TemperatureStarted by Guest_Neha Vensiyani_* , 29 Apr 2024 |
