Is there a way to quickly estimate the radiation exchange factor when calculating the radiative heat exchange area in a boiler ?
Thanks in advance.
Posted 06 April 2016 - 08:56 AM
Thanks in advance.
Posted 06 April 2016 - 11:40 PM
Hi Mag,
The radiation exchange factor is a measure of the amount of Radiation that is transferred between two surfaces based on their areal fractions relative to each other.
In your case, there is only a single boiler.
So what exchange factor do you wish to find out ?
Is it with respect to any surface you have considered, or just the amount of radiation it emits to the surroundings etc ?
Shantanu
Posted 07 April 2016 - 10:25 AM
I am looking at the radiation from the flame to the walltubes of the boiler.
Thanks for the reply.
Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023 |
Predicting Fouling Factor In ReboilersStarted by Guest_ProcessEng_12_* , 12 Aug 2021 |
Impact Of Ambient Temperature And Solar Radiation To A Gas StreamStarted by Guest_Jon K_* , 06 Apr 2023 |
Butane Thermal Expansion By Sun Radiation In PipeStarted by Guest_fedi.abdeljawed_* , 10 Jan 2023 |
Jet Fire Hydrogen - Heat RadiationStarted by Guest_panagiotis_* , 25 Nov 2022 |
