Dear visitors
Hello there, can I ask if anyone have any understanding on the temperature drop across the pipeline regarding the "pipe" selection on HYSYS in steady state modelling?
Warmest Regards!
Posted 07 April 2016 - 05:09 AM
Dear visitors
Warmest Regards!
Posted 07 April 2016 - 06:29 AM
Can you be more specific in your query with all necessary background?
Posted 07 April 2016 - 07:10 AM
When using Hysys for modelling a pipe segment, you need either define the ambiant temperature or heat loss.
The heat that transfers from the pipe and its atmosphere make a heat loss profil in Hysys.
Julien
Posted 17 April 2016 - 01:21 AM
Agree with Julien
It is obvious to consider heat loss according to heat balance equations defined in Hysys pipe segment or specify the ambient temperature and select the insulation thickness if exists.
Mahdi
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Extension Reaction Kinetic In HysysStarted by Guest_Ulbert Zsolt_* , 29 Mar 2024 |
