Hi, I need your advice.
I am doing PSV sizing of liquid phase and almost done.
But as you know, almost is never enough.
depending on API 520, I used SI Unit formula like A=((11.78 x Q) / (Kd x Kw x Kc x Kv)) x ((G / (p1 - p2))^0.5
Kd is 0.65 without rupture disk, rated coefficient of discharge
Kc is 1 without rupture disk, combination correction factor
Kv is 1 (first time assume), correction factor due to viscosity
Kw is 1 (refer to the API 520 table, back pressure 3 barg and set pressure 10 barg), correction factor due to back pressure
P1 is 1000kPag, upstream relieving pressure
P2 is 300kPag (back pressure depend on the tank maximum pressure because the relief fluid will return to the tank), back pressure
Q is 3333.4 litter/min, flow rate
G is 0.554 (Fluid is LNG), specific gravity
As a result, I got A is 1699.52mm2. So I chose orifice size L (1841mm2)
is it right? please check my result.
and I wanted to get Reynold's number, so I also used SI Unit formula like R = (Q x (18800 x G)) / (μ x (A)^0.5)
I already knew the A is 1841mm2, Q, G, but the thing is μ.
μ is absolute viscosity at the following temperature, centi-poise and I know LNG cP is 0.126. But if you put the all values in the formula,
result will be 6.4 x 10^6. is it right? If the result will be 6.4 x 10^6, Kv = (0.9935 + (2.878 / R^0.5) + (342.75 / R^1.5))^-1.0 = 1.01
So 1.01 is wrong result I think.
What is the problem with my calculation? I am not sure μ is 0.126. please clarify this point, too.
Please let me get this over with.
Thank you.
