Psv Fire Case For Electric Heater
#1 nivedita12
nivedita12
  • 46 posts
Posted 25 May 2016 - 10:37 AM
I have a fuel gas heater which is electric
There is a PSV on the outlet of the heater. As per API 521 SEC 5.15.2.2.2
it is used for vessels containing gases.
if i know the volume of the electric heater which will come from the vendor
How can I get the relief load .Is it using the same equation?
Thank you
#2 fallah
  • 4,958 posts
Posted 25 May 2016 - 01:23 PM
Please upload a simple sketch of the system you described to receive a proper and accurate response...
#3 nivedita12
nivedita12
  • 46 posts
Posted 26 May 2016 - 08:44 AM
Hi Fallah
Attahced is the sketch
#4 nivedita12
nivedita12
  • 46 posts
Posted 27 May 2016 - 09:35 AM
I have got the vendor information it is an indirect water bath heater and the area is given thank you all The area is calculated using the process heat transfer calculations.
Thank you so much
