Hi all
Are there any guidelines/standards for the design of deluge fire water system for Hydrocarbon pipelines?
Let me know if any further information is required.
Thanks in advance.
Posted 06 June 2016 - 01:44 AM
Hi all
Thanks in advance.
Posted 06 June 2016 - 02:19 AM
Pipelines are normally buried and do not require any fire protection / firefighting facilities.
Posted 06 June 2016 - 03:19 AM
ChemiFreak,
Cross-country hydrocarbon pipelines run buried as Dejan has rightly pointed out and need no fire protection.
If you are referring to in-plant hydrocarbon piping which is running across a pipe rack then NFPA 15 provides the guidelines for fixed water spray for fire protection. Clause 7.4.3.7 provides the guidelines for the water spray for pipe racks. Refer the table below for water spray densities for pipe racks as per NFPA 15:
Pipe_Rack_Water_Spray.png 35.9KB 3 downloads
Posted 06 June 2016 - 06:15 AM
Thanks Dejan and Ankur.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
