good day gentlemen
we notice a green oil in fuel gas system which is feed to ethylene furnaces. Just I want to know how green oil be form?
thanks
Posted 19 December 2016 - 01:52 AM
good day gentlemen
thanks
Posted 19 December 2016 - 12:18 PM
Green oil is an oligomer formed in the hydrogenation reactors. If you use fuel gas to regenerate the dehydrator it strips the green oil from the mol sieves and can foul the burners in the furnace.
Posted 20 December 2016 - 05:18 AM
Check if you've had a level upset in the green oil separation drum? It may have entered through the fuel gas line to the vapour space.
Posted 22 December 2016 - 05:22 AM
Thanks for your help
Control SystemStarted by Guest_Lyne_* , 03 May 2024 |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
Lube Oil System For TurbomachineryStarted by Guest_bckesim_* , 03 Mar 2024 |
