Hello friends: i have got to Design Treatment package for a cosmetic wastewater effluent. Can i get help on the methodology and procedure?
Design And Treatment Of Cosmetic Wastewater Effluent
Posted 22 December 2016 - 03:42 AM
Posted 05 January 2017 - 06:15 AM
Toksylone,
A great number of products from a good variety of production processes wold be involved for cosmetic plants. Even for the same product from the same equipment, lots of wastes streams can be discharged during changing lots. So there would be no general procedure for such wases. I once found lots of waste streams are collected from the designated source and exported for external waste treatment. Probably it seems that valuable materials are recovered from each specific waste stream.
If all kind of wastes are mixed together, no simple method wold be possible - slightly alkaline or acidic water, various kinds of solvents, oils, water- or oil-soluble organic matters with high or low viscosity, inorganic pigment particles with broad spectrum of particle sizes and colors, lots of surfactants, biomath-retandants, everything you can imagine. In that case, simple "incineration" followed with post treatment would be the only solution.
Anyone who has actual experience in the treatment of cosmetic waste stream could help you.
~Stefano G. Kim
Edited by sgkim, 05 January 2017 - 06:16 AM.
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
Rupture Disc DesignStarted by Guest_chaupradip_* , 13 Apr 2024 |
Falling Film Reactor Design CalculationStarted by Guest_Emranm02_* , 07 Apr 2024 |
