Dear all,
Please anyone answer my question.When an vessel is expected to operate at two conditions,ie max. and min. ,say 6&9bar.An PCV is placed to control the gas receiving at another vessel operating at 6 bar.how does the PCV control the pressure at both condition(max and min).
Plaese explain.
Thanks in advance,
With regards,
chem400
How Does Control Valve Works?
Started by chem400, Feb 03 2009 05:18 AM
Posted 03 February 2009 - 05:18 AM
Posted 03 February 2009 - 07:39 AM
chem400:
Your English writing is flawed. The sentence "An PCV is placed to control the gas receiving at another vessel operating at 6 bar" does not make grammatical sense and thus the problem is not understood.
Please furnish a clear and accurate engineering sketch of what you mean to say. Engineers communicate better with graphics. Also, ALWAYS PLACE SPACES BETWEEN YOUR SENTENCES WHEN WRITING IN ENGLISH. It is very difficult and annoying to have to try to decipher where your written thoughts begin and where they end. TWO SPACES between sentences is the normal, preferred element of style in English. Only books and printed matter are now using one space to economize.
Await your response.
Posted 03 February 2009 - 09:34 PM
QUOTE (chem400 @ Feb 3 2009, 03:18 PM) <{POST_SNAPBACK}>
Dear all,
Plaese explain.
Thanks in advance,
With regards,
chem400
Plaese explain.
Thanks in advance,
With regards,
chem400
Dearchem400,
Although whatever is said by the Respected Art is very pertinent and thoughts provoking indeed!
I will slightly hint that the description of your's simultaneously talks about control of
two vessel's pressure;if I am not mistaken.
If this is the 6 barg pressure you are intersted to control and kow the modality,then this is possibly
through closing of inlet control valve opening;if that is located on incoming pipeline from higher pressure source.
Hope this helps
Best Regards
Qalander
Control Philosophy In Steam ReboilersStarted by Guest_halkeshhulk_* , 07 May 2024 |
Control SystemStarted by Guest_Lyne_* , 03 May 2024 |
Wafer Check ValveStarted by Guest_Ali4269278331_* , 24 Apr 2024 |
Can Anyone Provide Me The Reference Datasheet For Deluge Valve?Started by Guest_Radha Krishnan Siva Kumar_* , 16 Apr 2024 |
Hydrocarbon Dew Point Control UnitStarted by Guest_BabRafiq1_* , 05 Apr 2024 |
