Dear all
How are you
Well iwas wondering how to decide the capacity of DM water storage tank required for given flow.
Water flow to boiler 34tph @ 23bar
I would grateful to have the calculation inspite of any figure arrived, thus will give more sense. Wait probly you may be having the spreadsheet to decide the spec for alla aux equipment required in boiler for a given capacity of o/l steam , can you forward or exude me where from i can get it
harry
Dm Water Storage Tank
Started by chau, Apr 03 2009 05:05 AM
Posted 03 April 2009 - 05:05 AM
Posted 03 April 2009 - 05:26 AM
Chau,
I notice that you are asking for spreadsheets to be donated to you all the time for the simplest of calculations.
If I recall correctly, you are a mechanical engineer of Kurukshetra University and the way you have been putting up your posts it is hard to believe that you profess yourself to be a mechanical engineer.
If you cannot perform the simplest of calculations using excel then you surely create doubts about your qualifications and also put a question mark about your alma mater. Have you tried doing calculations on your own? Have you ever thought that, let me try to do the calculations and then post the spreadsheet for some senior member's review.
I would think that any engineer, mechanical or any other discipline would like to progress by doing his own study and work and earn the respect of his peers and colleagues. You bely all those expectations from a young and dynamic engineer.
In a nutshell, try to be an engineer in the real sense of the word, that is the only advice I can give you.
Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , Today, 08:54 AM |
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Sulphuric Acid H2So4 Storage TankStarted by Guest_TeeEng_* , 08 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
