Flange Type Orifice Plate Minimum Flange Rating?
Posted 15 March 2010 - 10:11 PM
Can someone clarify if there is such requirement & if true what is the reason behind this requirement?
Posted 16 March 2010 - 12:47 AM
I would like to know is it true that Flange Type Orifice Plate need to have rating minimum of 300lb even if the pipe rating is less than 300? I looked up ASME B16.36 ('07) could not find a clause saying minimum needs to be 300 but the document only covers 300 to 2500 class.
Papaya,
FYI, not only for orifice plate but for other instruments as well such as flange mounted level/flow instruments the practice in some of the Oil & Gas Companies that I have dealt with is to have a 300# rating even if the line or system rating is 150#. I had the same query to my counterparts in the instrumentation group but I was not provided a satisfactory answer. There is no international code or standard that mandates this requirement.
The only thing that I can presume is that instruments may require more frequent maintenance than other components such as valves & frequent removal & installation would require a more robust construction which would lead to having a 300# rating. Another point would be that most instrument manufacturer's may have standardized the flange ratings as 300# and above for all flanged instruments.
Would like to know the opinion of a instrumentation engineer on this subject.
Posted 16 March 2010 - 01:10 AM
Papaya,
I also second Ankur's viewpoint with slight addition that this is
- For the sake of better Mechanical Integrity needs fulfillment,as well as
- Frequent operations reliability fulfillment
- the threaded tapping or connections employed for instruments related usage have much longer deeply inserted threads areas
- with much higher pressure withholding strengths and at times simultaneous vacuum withholding capability.
Hope this helps in getting an insight on the issue.
Edited by Qalander (Chem), 16 March 2010 - 01:13 AM.
Posted 16 March 2010 - 01:27 AM
Also since ASME 16.36 doesn't provide info on 150# orifice flange, will a 150# orifice flange still meet the ASME requirements?
Edited by papaya, 16 March 2010 - 01:28 AM.
Kitchen Stove Burner TypeStarted by Guest_Vegeta_* , 27 Jun 2025 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
![]() Restricted Orifice (Ro) After The Reciprocating Compressor? Why?Started by Guest_VolereePotere_* , 24 May 2023 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
