Fouling (trays Vs Packed)
#1 Guest_zili_*
Guest_zili_*
  • guestGuests
Posted 07 February 2005 - 01:26 AM
Hi! I was wondering if trays or packed columns are more subjected to fouling.
Also, which type of trays (bubblecap, valve or sieve) will foul the most?
If possible, can someone give me the detailed reasoning behind this question?
Thanks in advance!
#2 gvdlans
gvdlans
  • 619 posts
Posted 07 February 2005 - 04:54 AM
In fouling service you normally use sieve trays with relatively large hole sizes.
Reasoning behind the question is probably that if you know that you have a fouling service, you'd better select internals that can cope with this, otherwise your unit must go down quite often to clean out the internals. In a continuous process, going down can be extremely expensive...
#3 Guest_zili_*
Guest_zili_*
  • guestGuests
Posted 07 February 2005 - 05:11 AM
QUOTE
Why is it that sieve trays are better in fouling service?
What makes them less subjected to fouling than valve/bubblecap trays and packed columns?
#4 gvdlans
gvdlans
  • 619 posts
Posted 07 February 2005 - 05:49 AM
Sieve trays are less likely to have fouling problems because of following reasons:
- no moving parts
- large holes will take longer to plug than small holes
- no small corners etc.
#5 siretb
siretb
    ChE Jedi
  • 304 posts
Posted 08 February 2005 - 10:21 AM
This depends a lot also on the wetting rate. We manage, in several units, to operate sucessfully packings (both random and structured) with liquids that do contain a lot of solids. If the Liquid to vapor ratio is high, packings are not that much prone to fouling.
The dualflow tray is also very fouling-resistant. It has larger holes than a sieve tray.
With a sieve tray or bubble cap tray, you also have to account for possible solids accumulation in the downcomers and before the inlet weir.
