When gas composition is known as dry basis, how can I get ( in HYSYS)
water content in the feed, before water being removed, when temperature and pressure are known.
The gas is saturated condition at given temperature and pressure.
Regards.
Gas Composition In Wet Basis
Started by aanita, Apr 09 2010 08:20 AM
Posted 09 April 2010 - 08:20 AM
Posted 09 April 2010 - 09:54 AM
Well, I'm doing something like this (in CHEMCAD but I suppose it is similar in other simulator):When gas composition is known as dry basis, how can I get ( in HYSYS)
Regards.
1) Specifying my gas stream (air for example);
2) Specifying water stream (big amount of it);
3) Mixing them together;
4) Resulting stream is going to flash unitop with defined pressure and temperature;
5) In top stream from flash you have saturated gas;
6) Rest of water goes through bottom stream.
Hope this helps
Best Regards
Posted 09 April 2010 - 02:22 PM
Just add that dry gas stream with another stream having only water (amount start with 100 kg/hr, T & P can be as that of dry gas ) send this mixed stream to a separator , now observe liquid outlet (bottom out of separator )of separator ,
if this stream contains any water (m > 0 kg/hr) that means gas is saturated with water that’s why excess water is going as liquid from separator . Now separator gas out stream can be considered as saturated gas / wet gas .
In case liquid out of separator dosent contain any flow (m <= 0) then amount of water added is not enough to saturate the dry gas . Now add more water till you see some mass of water in the separator liquid out. Once you see water in the liquid out than corresponding gas out is the saturated gas / wet gas .
Note :
In case your gas contains some amount of liquid hydrocarbons , then this liquid is supposed to go through the liquid out . For this case use a 3 phase separator where liquid HC’s comes out as a separate stream (mid ).
This is a crude procedure I normally use , u can use any other simple procedure or check whether any utility / option available to find water required for saturation .good luck
Satish
Note :
Satish
Posted 14 April 2010 - 01:23 PM
Thank you very much.
Regards.
Regards.
![]() Final Composition Calculation Of First Iteration Of Methane Steam RefoStarted by Guest_kikisapsal_* , 14 Sep 2024 |
Syngas CompositionStarted by Guest_GmanGura_* , 13 Aug 2024 |
Problem With Writing Offshore Plant Design BasisStarted by Guest_Doneisbetterthenperfect_* , 01 Dec 2023 |
Diesel Composition For Hx DesignStarted by Guest_ganeshrbhat_* , 05 May 2023 |
Effect Of Lighter Components On Overhead Composition ControlStarted by Guest_Venkat @89_* , 23 Feb 2023 |
