Dear All
whate is the typical L/G ratio for flue gas desulfurization units?
I know, typically Lime is used as absorbent for desulfurization, if we want to use soda ash for a small plant, how should we calculate or find thumb rules for calculation of L/G ratio and pressure drop through absorber?
I found through searching different values for L/G that are not in a same order?!!
Is there any book or specific reference for design basis of this plant?
Thank you all
cruam
Typical L/g Ratio In Flue Gas Desulfurization Design
Started by cruam, Apr 10 2010 12:07 AM
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Hello, Design Of Natural Gas Liquefaction Processes.Started by Guest_guoyinyanliner_* , 18 Jun 2025 |
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
