Sizing Pipes For Heat Exchange
Posted 14 April 2010 - 09:03 AM
Situation: I have a bath (of volume V) of liquid nitrogen to evaporate using hot water heat exchange in steel pipe (because it is available), which comes in at pressure P. There is a known Tin and target Tout for the water. There is a maximum time t to evaporate everything.
Solving for: L, length of pipe.
Getting stuck at:
1) overall heat transfer coefficient. I can assume a diameter and wall thickness, but from there; where? I'm not sure whether the surrounding fluids or just pipe material will matter, and internet search hasn't made things any clearer.
2) I can get AN answer by finding
- the heat necessary to evaporate the nitrogen, then
- the minimum necessary rate of heat exchange using mcp*ΔT, the maximum time possible, and the above result
- h = ΔQ/(A * ΔT * Δt) where h is the heat transfer coefficient
but this a- doesn't account for the water pressure and b- still has the problem with the heat transfer coefficient, described above.
My background: I did this in school 10+ years ago and can do thermo in general but am getting turned around on this because of the pressure and what seem to be too many unknowns. It is at the fringes of what I normally do, so I don't have a lot of personal experience to say if a result is reasonable or not.
Posted 14 April 2010 - 09:59 AM
Alpha coefficients and resulting overall heat transfer coefficient will depend on the geometry of your system -> you must assume that -> is it coil or something else?
Posted 14 April 2010 - 10:16 AM
Does that clarify the question? Thank you for your input.
Posted 14 April 2010 - 02:56 PM
As for the evaporation rate it is calculated based on the volume of liquid Nitrogen (latent heat required to evaporate pool of Nitrogen, kJ) and the maximum time given for the evaporation process (hr). You simply divide the two.
Posted 14 April 2010 - 03:17 PM
Posted 14 April 2010 - 03:21 PM
Yes ... that's right... but those simple-look programs may help to organize your own excel workbook if you don't know how to start...then search the literature for equations.It's always better to do the hand calculations first, especially if they are not too complex. If one doesn't grasp the concept of a process by going through step-by-step calculation, he'll never feel confident with the results obtained by software.
Posted 15 April 2010 - 02:20 AM
Essentially what you have there is a pool boiling application, and for calculating heat transfer coefficient (and individual film coefficients) you can use the procedure for thermal design of kettle reboilers - as presented in the file attached below from Coulson & Richardson.
Thank you. I had gotten through the first steps okay, and your outline of the procedure confirms that. As for the boiling, the attached PDF is a good outline of the kettle reboilers; I am pretty sure I have never worked on these, so no wonder I was lost at that point.
Thanks everyone for the replies.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
