Mixing both lime and water to make lime slurry generates dust and vaporized fume with lime suspension.
Unfortunately, current system can't eject the fume properly. (See attachment 1. Current system.pdf, 2. system condition.pdf)
In spite of suggested alternative designs by partner as attached Alternative system (Water-jet scrubber).pdf, we can't apply it because both they designed existing system which has the problem described above and we are not able to verify engineering calculation about new solution.
Therefore I need to verify alternative system with calculating with your help. (See attachment 3. Alternative system (Water-jet scrubber).pdf)
Please advise me, referring to system condition below.
<System condition>
- Installed ventilation system
- Refer to Attachment 1. Current system.pdf
- Fan : 250mmAq, 30 m3/min (3.7 kW motor)
- System condition (Refer to Attachment 2. System condition)
- Tank
- Liquid : Lime slurry
- Temp : almost 80 ℃
- Retention time : 0.5 hr (30min)
- Lime slurry volume : 3 m3
- Tank diameter : 2.1 m
- Tank height : 2.4 m
- Tank
- Inlet
- Lime : 1,873 kg/hr (2.1 m3/hr)
- Water for slaking : 7.6 m3/hr (almost 4~5 BarG)
- Outlet
- Limeslurry : 8.2 m3/hr (9,446 kg/hr)
- Current system.pdf
- System condition.pdf
- Alternative system (Water-jet scrubber).pdf
note : engin.j.kim@gmail.com
Edited by J.Kim, 26 April 2010 - 11:56 PM.
