Hello
Is there any criteria of minimum "FLOODING FACTOR"? Minimum FLOODING FACTOR of my tower was 54%. It's rather low, isn't it?
Flooding Factor
Started by eastorca, May 01 2010 11:32 PM
Posted 01 May 2010 - 11:32 PM
Posted 02 May 2010 - 01:13 AM
Should be within the range (60-70%) , attached a link where it is mentionned 70% .
http://www.mycalcula...jmm/chem20.html
Use the search button , you may find more info.
Hope it helps
Hope it helps
Posted 16 August 2010 - 10:46 AM
Often a value of 80 to 85 per cent is used.
Literature: Buford D. Smith. Design of equilibrium stage processes. McGRAW-HILL Newyork. Chapter 15: Tray Hydraulics/perforated Trays
best regards
best regards
Hello
Posted 24 August 2010 - 05:54 AM
eastorca,
Following link will be very infomative for you.
http://www.cheresour...h__1#entry37969
Edited by P.Engr, 24 August 2010 - 05:55 AM.
![]() Colebrook's Equation - Friction FactorStarted by Guest_breizh_* , 10 Nov 2024 |
C Factor For Erosional Velocity For Multi-Phase Flow (Nat Gas/ ProduceStarted by Guest_Sam11_* , 10 Sep 2024 |
![]() Determining The F-Factor Following The Api 2000Started by Guest_Hachimi_* , 06 Sep 2024 |
![]() Environmental Factor "f" Calculation In Psv Fire CaseStarted by Guest_mahmooddalvi09_* , 17 Aug 2024 |
![]() Wind Enhancement Factor In Kumana Kothari CalculationsStarted by Guest_rlepra_* , 01 Dec 2017 |
