I have some question about Amine plant for co2 recovery from flue gas:
as shown in the attached file, there are a washing water cooler for absorber and a reclaimer in a conventional amine plant.
in my simulation I consider a washing section inculed 3- 4 tray top of the absorber. at first I had just added a fresh water stream to the top tray (tray1) as a wash water without cooler and recycle to column. but I saw in amine plants a washing cooler should be included. when I did so, the amount of MEA loss in the overhead stream increased and I had to increase amount of make up water. Acoordingly, the question is that what is the basic reason to have a wash water cooler in spite of that it doese not have significant effect on wash water consumption??
the second one is about reclaimer,
I've red that heating and adding some water and soda ash to a reclaimer should be continued to reach the same MEA composition in the outlet vapor of the reclaimer as in the lean MEA fed to it and this temperature should not exceed 148 C for MEA (Gas Purification) is it correct in practice??
the other question is about Amine loss because of heat stable salts formation. How can I calculate or find the amount of HSS at the operation condition applied in my case? I've found some data for amine losses due to vaporazation or average amine loss in the plant (1.6 Kg/tonne CO2)but not especific about HSS!!
the final question:
in co2 recovery plants a soda ash tower and a [b]Potasium permangenate column is necessary. I can not find any specific information about them to calculate the amount of Soda ash or KMno4 needed in my case. is there any guidline for it?
Thank you all
Cruam
Edited by cruam, 04 May 2010 - 01:05 AM.
