Hi everybody!
I need to know the average market price of an industrial refrigerant (for a condenser on the top of a distillation column).
I guess I could use some compounds like hydrofluorocarbons, chlorofluorocarbons (R-12, R-125, R-32, etc.); the temperature of the distillate is 270 K.
Help me please!
Refrigerant In Condenser
Started by tizanidine, May 06 2010 06:52 AM
Posted 06 May 2010 - 06:52 AM
Posted 06 May 2010 - 04:56 PM
Why do you want to use a refrigerated coolant in your condenser? What is the boiling point of the overhead distillate at the overhead pressure? If that boiling point is above about 120 degrees F (49 degrees C), then you could probably use either cooling water or air cooling.
Posted 07 May 2010 - 12:52 AM
The price will depend on the market and availability of the product you need. Identify the refrigerant you need, and then start making inquiries around to see where and at what price you can get it.
For 270K (-3 degC), Propane appears to be the cheapest and the simplest solution.
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
CondenserStarted by Guest_Kentucky08_* , 27 Jan 2025 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
Condenser Inlet Stream TemperatureStarted by Guest_Sampath123_* , 06 Jul 2024 |
