Aspen Plus Severe Error In Physical Property System
Posted 21 May 2010 - 07:34 PM
I am trying to sperate two compnonets using DSTWU COLUMN in Aspen Plus, I got the error shown below.
SEVERE ERROR IN PHYSICAL PROPERTY SYSTEM
WATSON HEAT OF VAPORIZATION MODEL HAS MISSING PARAMETERS:
DHVLWT/1ST ELEMENT (DATA SET 1) MISSING FOR COMPONENT PBR3
DHVLWT/2ND ELEMENT (DATA SET 1) MISSING FOR COMPONENT PBR3
****PROPERTY PARAMETER ERROR
ERRORS ENCOUNTERED IN CALCULATION OF LIQUID MIXTURE MOLAR ENTHALPY USING
OPTION SET NRTL-RK FOR H
After getting this error I added enthalpy of vaporization for PBR3 in pure component data , still getting same error. Please help me how to solve this error.
Thanks,
Nageswar Reddy
nrkota7@gmail.com
Posted 07 June 2010 - 09:57 AM
I am also getting this error when I work with a mixture of benzene, water and NaOH... The problem is with the NaOH... did you manage to solve this issue?
Thanks!
Eliana
Thanks,
Nageswar Reddy
nrkota7@gmail.com
Posted 07 July 2010 - 07:09 PM
Thanks,
Nageswar Reddy
nrkota7@gmail.com
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Physical Properties Of Liquid Discharge For Kod SizingStarted by Guest_mahmooddalvi09_* , 26 Feb 2025 |
