I have been having some problem with convergence in Aspen. After initiating with equilibrium mode in a co2 MEA system, I then use then result for rate based mode. But at the end, I still find some co2 at the output stream whereas in the equilibrium mode, all the co2 were absorbed. Increasing the MEA flowrate did absorbed all the co2. But if I initialized the simulation, only the rate based simulation converges. The result are still good since the rate based was use to initialized with the equilibrium.
Do you thing there is a problem if only the rate based converges after reinitializing?
Equilibrium & Rate-Based Mode Aspen Plus Simulation
Started by donchris34, Jun 17 2010 05:05 AM
No replies to this topic
Posted 17 June 2010 - 05:05 AM
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Aspen Plus Conceptual Mof Synthesis Model: Elecnrtl, Ionic Leachate, PStarted by Guest_Momo_212_* , 16 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
