Dew Point And Water Ppmv
Started by Wajid, Jun 21 2010 01:20 AM
Posted 21 June 2010 - 01:20 AM
I am getting Dewpoint of natural gas -74 deg C at 0 psig. Water contents are calculated to be 1.4 ppmv.
At the line pressure of 680 psig dewpoint is calculated to be -45.6 deg C. Will the water concentration in ppmv remain same, increase or decrease?
Posted 21 June 2010 - 08:27 PM
Looks like what you've done is increased your pressure, kept ppm(v) constant ,and found your new dew point.
ppm(v) is proportional to the ratio of the water vapour partial pressure to the total system pressure.
Posted 21 June 2010 - 09:43 PM
Thank You very much mbardfast, now I have a second opinion to convince my colleagues.
Posted 14 August 2010 - 01:29 PM
By definition parts per million by volume does not change with pressure.I am getting Dewpoint of natural gas -74 deg C at 0 psig. Water contents are calculated to be 1.4 ppmv.
Edited by DrDewLittle, 14 August 2010 - 01:30 PM.
Posted 15 August 2010 - 02:57 AM
Dear,
When it is said that the natural gas is at its dew point temperature or pressure it will have a certain saturated water unless you route your gas through an adsorbent bed to remove saturated water. Now when you alter the conditions like Temperature and Pressure, saturated water could become as free water e.g. in case-1 if the temperature falls down and case-2 pressure goes up (change is say substantial), you may find free water and subsequent change in water concentration in flashed gas. You have to judge the change in these parameters.
Separation Ammonia From A Methanol/water SteamStarted by Guest_SlimChem_* , 23 Dec 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
Simulation Of Natural Gas Water Dew PointStarted by Guest_guoyinyanliner_* , 03 Nov 2025 |
Dew Point CalculationStarted by Guest_Aditya000333_* , 17 Sep 2025 |
