Can some one tell me if I can use the "SCRUBBER DESIGN (PACKED COLUMN)" spreadsheet to design a stripping column.
This spreadsheet design the packed column wich removed components in gases using solvent. but I want to use it for a column wich removes components in water (Hydrocarbon for exemple) with an airflow.
if I can't use this spreadsheet, is there an other to do this. Can you help or advice me to make the disign
Thank you.
Scrubber Design (Packed Column)
Started by anina, Jun 23 2010 07:56 AM
Posted 23 June 2010 - 07:56 AM
Posted 23 June 2010 - 09:07 AM
Anina,
Try using the spreadsheet at the following link:
http://www.chemsof.com/spreadsheet.htm
Posted 24 June 2010 - 03:58 AM
Thank you very much, Ankur.
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
