I have chance to size the relief valve in case of blocked outlet (110% max). I try to use Hysys to size the orifice size of relief valve by using RV equipment in the program in steady state (I didn't use depressurize in utility because this case is not fire case or blowdown case). The results shows orifice size "E" but when I manual calculate by hand (API 520), I found that the correct size is "J". So I have question that
1. Why the result is different?
2. Actually, can RV in Hysys use for relief valve orifice sizing?
3. If Hysys can use for the sizing, it will automaticall change the equation of orifice calculation in case that source is change to Liquid or Gas or Steam? And it will calculate critical point and select the equation for user or not?
However, pls try to see design parameter as attachment.
Best Regards,
elvisnew
Edited by elvisnew, 09 July 2010 - 01:32 PM.
