We are studying the waterhammer in a Refinery. Since the bulk modulus is involved in this study, we will like to know where to find the bulk modulus at different temperatures and pressures for several refinery fluids such as kerosene, diesel, atmospheric and vacuum residue.
We have found some info about kerosene in the handbook of aviation fuel properties, but not further information has been found in the net.
Thanks for your cooperation
Jorge de Orueta
Refinery Fluid Bulk Modulus
Started by JOA, Jul 16 2010 04:23 AM
Posted 16 July 2010 - 04:23 AM
Posted 19 July 2010 - 11:33 AM
I had a search on google long back and had found one google-book hit which gave following relation for isothermal bulk modulus as function of temperature, pressure and API gravity of fluid.
Bulk modulus = A+B*P-C*(T^0.5)+D*(T^1.5)-E*(API^1.5)
where
A = 2.62E6
B = 9.203
C = 1.42E5
D = 73.05
E = 3.41E2
P = Pressure in psig
T = Temperature in deg Rankine
API = API gravity of fluid
I don't remember the name of the book, but it is certainly available in google books. Please confirm before using with a known fluid.
Hope it helps.
Sachin
where
A = 2.62E6
B = 9.203
C = 1.42E5
D = 73.05
E = 3.41E2
Hope it helps.
Sachin
![]() Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
![]() Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
![]() Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
![]() Literature To Read For Refinery Oil MovementStarted by Guest_Noman97_* , 09 Nov 2023 |
